1 - 1 of 1 Posts
I have just changed the bulb on the driver's side headlight on my 2007 Beetle. Got it out just fine, changed the bulb, slipped it back into place until it clicked, then turned the lock screw until it was tight, but the headlight is still loose...I can partially pull it out. I have repeated the process a few times with the same result. HELP!!!
EDIT/ Never mind. I just found out the male guides on the car have slip into the female guides on the headlamp assembly or it can't lock into the right position. Everything is good now.
1 - 1 of 1 Posts
