Issue: Start car and Able to shift car into Drive , reverse 2,3rg and so forth, but nothing happens. there is no motion in ether direction.
Type: 2.0 Gl 4 Cylinder automatic transmission
I noticed that when I press the break, something clicks in the gear box. As if there is a short connection or a loose cable.
I check the shift cable under the air box and it seems to be fine in that location but the cable that goes to gear shift seems to be really flexible as it furthers into the car.I do not know if the cable is supposed to be stiff and non moveable?
Or is there a senor in the shift box that's dead?
