Replaced glow plugs, replaced brakes, then fuel filter. Low power in 1st and 2nd gear. Took to Autozone, codes P1550, P 1144 and P0380 came up. Reset and now power seems to be back. Don't know what P1550 means. Help!!! Thanks!
To answer your question -
17958/P1550/005456
From Ross-Tech Wiki
Jump to: navigation, search
Contents
[hide]
17958/P1550/005456 - Boost Pressure Control Valve (N75): Control Deviation
Possible Symptoms
  • Irregular behavior
  • Reduced power output
  • Limp mode
Possible Causes
  • Hoses/Pipes incorrect connected, disconnected, blocked or leaking
  • Charger Pressure Control defective
    • Solenoid Valve for Boost Pressure Control (N75) defective
  • Turbocharger defective
Possible Solutions
  • Check Hoses/Pipes to/between Components
  • Check Charge Pressure Control
    • Check Solenoid Valve for Boost Pressure Control (N75)
  • Check turbocharger
Retrieved from "17958/P1550/005456 - Ross-Tech Wiki"
Category: Fault Codes
M.
