1 - 9 of 9 Posts
Just lowered it 2 inches and put 19's on it. Went with a 19x8 and 45mm offset. 225/35/19 tires. They are perfect and 0 rubbing even on big bumps. I am glad i didn't do the 35mm offset like I was told to do. Putting the factory style hoop wing on next week.
Looks good. What camber kit did you use if any? I recently put 19x7.5's on my NB and noticed some negative camber in the rear.
camber
Everything is factory. The front end turned out perfect. The rear is basically a straight axle so it is nod adjustable but mine looks the same way, all of them do. I am going to cut a coil off the front springs this week to get it down a little more. I like a little rake in it.
Everett Street in May
Oh man does that look good! Wow great set-up.
Sent from my Autoguide iPhone app
So how about an update pigpenracing? I'd like to know how it went with the spring cutting and the spoiler add.
1 - 9 of 9 Posts
