I spent many hours today fitting a an ebay special window regulator assembly, multiple times. Old cable was chewed and the connector had broken. The cable is too long even after setting it to the taughtest it could get it. Didn't get the job finished will have to get an OEM regulator kit. Buy cheap buy twice.
I'm not sure why the roof wont go back up. Maybe it needs resetting. I couldn't operate it manually though as the flap on the side that i was not working on, is now stuck down. I didn't have the brains to disconnect the ball arm when it was up. Now the roof is stuck down, i don't have a garage and i'm in England, so it's proably going to piss down with rain at some point soon. I have the semblance of a cover over it for now.
I would be grateful if anyone could let me know if there is a way out of this pickle?
2004 model, right hand drive, right hand side rear panel removed, regulator connected and working.
Can the stuck (down) flap be lifted manually without breaking it i.e. can the ball joint doofer be unclipped while the flap is down? That would enable me to get roof up manually at least.
I have a cheap code reader, not a proper VW one. It shows live data but i'm not sure to what extent. Last time the roof got stuck down, closing it manually reset it successfully but i can't do that this time.
I presume the inner rear panel being off does not stop the roof working either?
Thanks in advance...
