Hi its me again. I got 2003 gls 2.0 5 speed. Went to to hit the clutch on the highway to slow down after that the clutch got stuck to the floorbard so i picked it up with tip of my crocs. Seemed to still have pressure. So i just read some forums and went about my day. Drove to my destination. And there seemed to be a chatter taking off and going from 1st to 2nd. Ended up doing the 1st gear to 5th gear going 25 in 1st ,and both the mileage an hour and the rpms had the same rate of movement. So now i have to drive back home got on the highway everything seemed fine all my gears worked. So im in 5th and went to down shift to 4th and when i went to go back to 5th it didnt want so i gave it a little more force and i just hear a loud pop. The clutch has lost all pressure. No visible leaks. I cant even move in any gear everythings a natural.
I have no idea if its the slave the master or the clutch or if my whole transmission is messed up
