My check engine light came on the other day and I just had the codes read.
Codes 102 and 234 showed up as problem codes.
The mechanic identified for me that one code was for a bad mass air flow sensor and How to test and replace a VNT turbo actuator VW TDI and VNT actuator adjustment identified that the 234 code is for a vane actuator in the turbo unit.
I do have bad glow plugs though I live in the tropics so I have not been in a rush to replace as I just bought the car and it had some other priority repairs first to address. I hear that the vane can stick from carbon of the engine which I am sure can be caused more so by bad plugs that lower the emission standards. I read on the link above that the code could show from a bad vacuum hose and I do hear what sounds like a vacuum leak when the car is running.
Any advice would be greatly appreciated. Thank you in advance.
