on the 2000 VW Beetle GLS 2.0L cross member exhaust bracket.. how many had this to rattle and the noise come thru at the gear shift..is this common.. new bracket stop this..
Thanks Again
These commonly break; then it can cause problems by stressing the flex/down pipe, eventually the flex pipe will break as well. If you take it to a exhaust shop; they can typically fix, weld, replace whatever parts are damaged or broken. I would definitely; check your flex pipe, as well.
Welcome to the great and wonderful ORG! Many fantastic cars, people and answers lurk in this great land. If you haven't done so already, take time to fill in your profile and post a few photos so we can ORGle them!!
I had that issue on my 2002 a quick weld took care of it!
