which
which fuse melted? The alternator wire? I wouldn't unless it's temporarily like..ie one day or just to drive to the repair shop. You need to find the root of the problem also. Your alternator's regulator could be bad and putting out too much voltage or the battery is shorting out and going bad and it's pulling too much current making that harness wire too hot and melts. with the car at Idle put a digital volt meter on the battery posts and you should read between 13-14.5 volts DC.
