hi, i got misfire and error codes, pls help!
Error Number Error Description
17574 (P1166)---Unknown Trouble Code
17705 (P1297)---Unknown Trouble Code
16587 (P0203) Injector Circuit Malfunction - Cylinder 3
INTERMITTENT
16684 (P0300) Random Misfire Detected
16687 (P0303) Cylinder 3 Misfire Detected
17705/P1297/004759 - Ross-Tech Wiki
16587/P0203/Cyl.3, Injector Circuit Fault in electrical circuit
17574/P1166/Bank1, Long Term Fuel Trim, Range 2 Rich Limit Exceeded
There are some descriptions of your other unknown codes.
We really need some more information though. How many miles? Have you ever changed the coil packs? Spark plugs?
i am second owner, did not change those in my hands. 110K miles now. 2004.
could these code related with MAF?
Just an update, the problem happened only in cold raining day. It is moisture/temperature related.Most likely MAF sensor aged out. Ordered one from ebay for $50. Will post updates here after trying it. :)
I'd say its coil pack related if its happening in the rain. The coil packs are problem areas for sure.
