Hi I was on the interstate and lost power misfire 2 & 3 cyc so I pulled the plugs and this is what they looked like I bought new plugs and now its just cyc 2 any ideas?
Could be something wrong with your tune. Definitely running way lean and detonating at the rate of self destruction.No codes except misfire I'm running 36 lb injectors 4 bar regulator 3" maf united tune and I run 93 only nothing less
Sent From My HTC EVO On Boostmobile
Well, something isn't working in your set up that causes your major detonation. If it'sHow could the tune go bad? I have an lc1 innovate wide band and it reads like 14 when idling and goes to like 12.4 when I'm getting on it
I am sure you can find that here by search above or google it. I would love to know how tooHow can I check to see if something is wrong with the fuel injector/s
