Why would the original Monsoon AM/FM receiver and tape deck suddenly go silent with the digital screen first showing "SAFE MODE" then going to the number "1000?" It did this more than a year ago when I had a Scan Gauge II hooked up to my OBD II port, and kept doing it until I unplugged the Scan Gauge, but the local VW Dealer's Service Dept. couldn't see how that could be causing it. I eventually ended up getting a new antenna base which cured my AM reception problems that I was having and I rehooked up the Scan Gauge about 3 mos. ago, and everything worked fine until the Monsoon went into this "SAFE MODE" and "1000" today, but then started receiving fine again after I had the Monsoon shut down for a couple hours. However, any idea what could be causing this? The Scan Gauge is still hooked into my OBD II port, but, like I said, the local dealer ruled this out as a cause....
