See my avatar picture? Pull the front fenders and bumpers as a unit. Remove the radiator and ac condenser, then disconnect all the various hoses and wiring clips, being careful to label whatever you’re unsure of. Then attach your engine lift and raise the engine about an inch, loosen and remove the motor mounts. Lower the engine onto the legs of the engine lift and slide it right out the front, transmission and everything.
You can’t believe how much easier that is than trying to use a shoehorn to get that engine out and then back in especially if you detach it from the transmission and leave the transmission in the car.
I’m not as familiar with the gas engine I only have diesels but I believe that’s an air pump.
Ha Ha, I need to do the same. When I changed my radiator, I took lots of pictures and labeled parts and screws in baggies as a I went because I knew it wouldn't get to put it back together right away. Otherwise it would have been a bear figuring out which screws were for bumpers, brackets, etc.Thanks for the input. I have labeled everything and took pictures as I am going. Even if I know what it is. The mind is not as sharp as it once was. Something about getting old.
I am putting my screws in a fishing lure tote and labeling what they came out of and putting dividers so I can keep it all together. I am only getting a couple hours at a time on Saturday’s. Maybe I’ll have it done by the end of November lolHa Ha, I need to do the same. When I changed my radiator, I took lots of pictures and labeled parts and screws in baggies as a I went because I knew it wouldn't get to put it back together right away. Otherwise it would have been a bear figuring out which screws were for bumpers, brackets, etc.
Its part of the PCV valve ... go to a junkyard and pull the part yourself .... mine was cracked, I pulled the part and the guy asked if I would pay a dollar for the part .... I said yes and went back to get the rest and was charged five dollars.I started pulling my daughters blown 1.8T yesterday and broke a plastic elbow that is above the oil filter. Can anyone tell me what this part is? Maybe even a part number. Thanks in advance. View attachment 255705
