Ali's Dad
I borrowed VCDS and ran it against my 03 1.8T NBC. I was expecting some issues with the transmission as I get the brackets around the gear selector indicator in the instrument cluster after warm up. Since it is 11 years old and the PO did no maintenance I expected other issues. SO here they are:
Sunday,19,October,2014,10:24:58:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1Y - VW New Beetle Cab
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWCD21Y63M327020 Mileage: 181510km/112785miles
Address 01: Engine Labels: 06A-906-032-AWV.lbl
Part No: 06A 906 032 KT
Component: 1.8l 5VT NB AG6 G 4926
Coding: 00004
Shop #: WSC 00066
VCID: 7AF1EC3166C4789
3VWCD21Y63M327020 VWZ5Z0C3307068
2 Faults Found:
18057 - Powertrain Data Bus
P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
18014 - Rough Road/Engine Torque Signal from ABS
P1606 - 35-10 - Electrical Malfunction - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No: 09G 927 750 P
Component: J1102D0E.MOT 0324
Coding: 0065535
Shop #: WSC 01317 552 00000
VCID: 3E7920216A6C949
3 Faults Found:
01045 - Tiptronic Switch (F189)
008 - Implausible Signal - Intermittent - MIL ON
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
00364 - Terminal 15 Slave
002 - Lower Limit Exceeded - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00066 000 00000
VCID: 346D020954204E9
1 Fault Found:
00668 - Supply Voltage Terminal 30
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No: 6Q0 909 605 AM
Component: 02 AIRBAG VW7 0619
Coding: 0012338
Shop #: WSC 00000 551 00000
VCID: 820114D1DE14B09
1 Fault Found:
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1C0-920-x4x.lbl
Part No: 1C0 920 941 N
Component: KOMBI+WEGFAHRS. M73 V03
Coding: 03234
Shop #: WSC 24125
VCID: 2B5F1975D91E111
1 Fault Found:
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN V032
Coding: 00006
Shop #: WSC 00066
VCID: F0E54E19B0B8B29
1 Fault Found:
Address 26: Auto Roof Labels: 1Y0-959-255-HYD.lbl
Part No: 1Y0 959 255
Component: VSG NBC 2604
Shop #: WSC 00000 000 00000
VCID: FDFB672DA7EACF1
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 G
Component: 6J Komfortgerát HLO 0004
Coding: 00256
Shop #: WSC 00066
VCID: 3B7F2935297E811
Subsystem 1 - Part No: 1Y1959801
Component: Tõrsteuer.FS KLO 0001
Subsystem 2 - Part No: 1Y1959802A
Component: 6J Tõrsteuer.BF KLO 0001
Subsystem 3 - Part No: 1Y0959811
Component: 6J Tõrsteuer.HL KLO 0001
Subsystem 4 - Part No: 1Y0959812
Component: 6J Tõrsteuer.HR KLO 0001
6 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01331 - Door Control Module; Driver Side (J386)
00932 - Electric Window Motor; Drivers Side (V147)
62-00 - No or Incorrect Adjustment
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 157 D
Component: Radio DE2 0006
Coding: 06031
Shop #: WSC 00066
VCID: 1D3BC7AD97AAEF1
No fault code found.
End ---------------------------------------------------------------------
I looked up all the codes on the Ross Tech site and have a general idea where to start. WHat I don't have is a Bentley. So some assistance is needed in tracking down the locations for checking the ABS issue. I will check what wiring I can around the brakes themselves. But from the way this reads its not a specific tire but the ABS system? Where is the ABS module and can I test it somehow?
Also, any assistance with the Central Conv. issues is appreciated. IT all shows voltage too low - is this perhaps an issue with module in the drivers door? Maybe the solder points are bad?
As an FYI - I have had a history of issues with the fuse panel on top of the battery melting. I have replaced 5 and currently have a new one, with a new heavier guage wire to the Alternator - plus a new alternator and a new CPS.
Trying my hardest to keep this thing running. Its my daughters, she is away at Bama in her freshman year (driving my reliable HOnda Accord).
Jeff
Ali's Dad
Thanks Billymade.
I did some searching (on here and other forums). Based on my searches I cleared the codes - they may have been old codes from when the fuse box melted. Ran a new set and voila - all of the intermittent ones related to power went away! YAY.
This is the latest scan:
Sunday,19,October,2014,13:47:52:32264
VIN: 3VWCD21Y63M327020 Mileage: 181540km/112803miles
Coding: 00004
Shop #: WSC 00066
Readiness: 0000 0001
Coding: 0065535
1 Fault Found:
008 - Implausible Signal - MIL ON
Coding: 0019970
Coding: 0012338
Coding: 03234
Shop #: WSC 24125
Coding: 00006
Shop #: WSC 00066
Coding: 00256
Shop #: WSC 00066
1 Fault Found:
Coding: 06031
Shop #: WSC 00066
Looks like the Tiptronic switch is the only issue. I am going to disassemble the shift mechanism and see if the magnet has slipped (there is a tech bulletin out on it - 37 07 07 Feb. 2, 2007 2013850 ). Well and the driver electric window motor!? - don't have any issues with it at all so I am guessing it is probably something to do with the solder points.
Ali's Dad
Discussion Starter · #6 · (Edited)
Pencilneck - borrowed it from a friend. Did not want to update someone else's stuff. I did tell him it was in need of updating.
As for the PRNDS issue: I think it is resolved. Turns out the magnet on the Tiptronic selector was off. Found the magnet and its holder laying loose. So I glued it on.
Now that I have all the center console off - I will just mosey right into the blend door repair.:):)
