Hello all,
Having fought with the car for several hours today? We finally changed out the thermostat for a factory one. It was changed at some point. It had a rubber seal type that wraps around the thermostat, not the factory thermostat goes in first and then a big o-ring goes in 2nd.
At any rate. We flushed out all the old green ****. And the radiator hoses where factory and due for replacement.
After we had clear running water out of the car? I drained it again by pulling the hose to the rad (it was getting replaced anyway) and put in a quart of G13 in the overflow. (I rarely dilute the first quart, as that mixes with the distilled water still in the block and heater/lines.) I prepped a mix of 50/50 and topped off the 'orb' and we started it up. It sucked it down pretty well, and I refilled it again using the 50/50. We then let it run for about 15 minutes. It made it to temp and the upper radiator hose went from "peewarm" to HOT. The hose going to the thermostat was running 'warm'.
As a side bar: I'm used to the waterpumps pushing fluid OUT of the thermostat housing and not drawing it 'IN' as seems to be the case here. So that did throw me a bit. Seems I have to remember there are cars that have 'stats' in the lower hoses.
At any rate. We got the "Boiling" action in the 'orb'. The heater hoses are both flippen HOT!! So I was expecting the usual fantastic heat from the car! We had nadda. Zero heat and the heater hoses are about as hot as the sun!
So two questions: (I didn't see it answered under the other thread regarding this issue)
Is that boiling action actually normal? Kinda looked like an old style tea kettle.
The small line going into the 'orb'? It's not blocked, I blew into it after the flush out and I did hear the 'bubbling', so I know it's not blocked up.
Is there any tricks to getting the heat back into this thing? It had great heat going into the garage, flush and change out the hoses and thermostat and no heat?
I figure we probably have a huge air pocket in the heater core..and probably only have flow through the end cap of the core.
So the two questions:
Boiling Coolant in the 'orb'
Tricks to burp out/get the heat working again!
We fought with it for quite a while...and ran out of day light and patience LOL.
Thanks in advance!!
S-
Thanks in advance!!
S-
