irregular member
Other than a junkyard or dealer, is there a resource for the n75 harness specifically the metal clip on the connector? I was doing some work under the hood the other day and I badly bent the metal clip. Now the connector will not stay on and I have no boost along with the corresponding fault codes of a bad n75.
The metal piece in the picture is all that I need.
(not my pic)
You should be able to use a number of zip tie wraps to secure the connector/sensor; while you order/wait for a new one. If you look closely at the connecter; the part number will be imprinted on it (you may need a magnifying glass or take a photo with your cell phone). Once you get the part number; search online or order it from your local vw dealer. I think you will have order the whole connector; I do not believe they sell the wire retainer by itself.
Gustav
(not my pic)
Zip tie the plug to the N75 once connected this should cure your lack of boost issue till you can find a replacement part. You best bet for replacing the hasp will be to replace the entire plug so you will need a donor 1.8T wire harness from a MK 4 Beetle, GTI or Jetta they will all have the same style N75 plug!
