2001 NB TDI, 240k miles. I bought it new and sold it to a friend recently. The warning chime that tells you the headlights are on, seatbelt undone, freezing, and low fuel stopped working.
I read several threads about door switches, but all of the interior lights work. I used VAG COMM to check the instruments and did the output tests and got no noise when I got to the chime test.
I found one thread where the chime had failed, and the entire cluster was replaced under warranty. Has anyine replaced the chime before? Anyone have a bad cluster that can send me the noise maker?
I read that the Golf's and Jetta's have a noise make in the relay panel, but apparently for the Beetle it's in the cluster.
