Every one calls me Fuzzy
i am lookin at a NBC and it is throughing a p2181 code for cooling system performance. can any one tell me what this code means and how much it would cost to fix. It has 110k on it and the asking price is 8k i am bluebooking now. please let me know soon.
Water pump, thermostat, or temperature sensor ... Timing belt/Water Pump Service (replacement of both) is a big issue, $750-$1200 if Seller does not have documentation, this is mandatory at stated mileage. What year is the NBC?
18613/P2181/008577 - Performance Malfunction in Cooling System
Possible Solutions
  • Check Engine Coolant Temperature Sender (G62)
  • Check Coolant Thermostat
  • Check Engine Cooling System
    • Put the key on, fan speed on 1, and push the a/c switch. Are both fans kicking on? If not, you found the problem.
    • Put the key on and fan speed on 1 with temperature set to hot. Does heat come out readily from the vents?
      • No. Probably the water pump is gone.
      • Yes. Probably the thermostat is gone.
Special Notes
  • Check the stored Freeze Frame data with this fault code. Freeze Frame information will be found in the fault code description (if the module supports it) or in Generic OBD-II if the vehicle complies with those regulations.
    • Freeze Frame data stored at -40*C is generally an indication of a faulty ECT or wiring.
    • Freeze Frame data stored at +140*C is generally an indication of a faulty ECT or wiring.
    • Freeze Frame data stored with in the 68*C ~ 80*C range is an indication that the vehicle was close to, but not within, the cooling systems normal operation range. The Thermostat itself or Cooling system components may be at fault.
Retrieved from "18613/P2181/008577 - Ross-Tech Wiki"
