Do you have junk yard near you? Check there. I'll check around onlineI need the plastic connector that slides into the MAF, ours broke inside and is causing a low voltage CEL.
Anyone have one in a junked car, or know of a site that might sell them?
THANKS!
Book marked thanks i try to find it.Just get a new MAF connector housing.
Volkswagen New Beetle 2.0 > Search > Connector Housing > ES#4303 Mass Air Flow Connector Housing - Female Connector - 1J0973775A
I broke two of my Coil on Plug connectors when I did a Spark plug change on My beetle and just ordered the proper connector housings, removed the pins in the old housing (That is a bit tricky but can be done with a bent paperclip or in my case I used a dremel to carefully cut the housing open and removed the pinsBook marked thanks i try to find it.
sent from DROID. 2001 NB 2.0 manual Cyber Green
Thanks so much! I knew there had to be new ones somewhere!Book marked thanks i try to find it.
