I am in Bullhead City and have a repair shop here that will install the compressor, dryer, vac the system and fill it with Freon for around $400.00. Got to ROCKAUTO.com for the a/c kir for $268.00. You are alittle far from here, but search around different shops. I'm sure you'll find someone cheaper.
Hope that helps
The poster also needs to have the condenser replaced, I'm guessing that is where the leak in the system occurred otherwise there would be no reason to replace that part.
So $400 for your labor and charging the system, and then 270 for the hardware, not sure what is in that kit. That's $670 right there.
Now add in about $150 for the condenser and we're over $800. Add the labor of installation which the VW manuals say is about 7 or 8 hours and you're close to the $1400 originally mentioned.
This is an expensive repair due to that condenser change which is why for myself I did all the major replacements on my bug as my repairs needed even more work than the OP.
Just be glad none of the hoses are leaking, on my Beetle I had to have 3 hoses replaced, the condenser, the compressor, the dryer, and expansion valve. The only thing original now is one hose and the evaporator. The hoses cost the most of all parts as only VW has them. Hoses cost me over $1000 in parts, each was around $350.
