Hello all. My Bug was starting fine. I had it up on stands putting the fender linners back on. I hooked up my Canadian tire OBDII reader. Cleared the faults. Put the car back on the ground and NO GO. The car turns over very well. (New Battery) but just won't fire. I checked the fuel pump and it's fine. I picked up a Vag-com. This is what I got for faults. I swapped out the fuel relay but still no go. Does anyone have any ideas.
Thanks Wayne
Address 01: Engine Labels: 06A-906-032-AVC.lbl
Control Module Part Number: 06A 906 032 C
Component and/or Version: 1.8l 5VT NB HS G 3077
Software Coding: 00001
Work Shop Code: WSC 00066
VCID: 1E3D2611B0C5
12 Faults Found:
P1636 - 35-00 - -
17633 - Fuel Injector for Cylinder 1 (N30): Short to Ground
P1225 - 35-00 - -
17635 - Fuel Injector for Cylinder 3 (N32): Short to Ground
P1227 - 35-00 - -
17636 - Fuel Injector for Cylinder 4 (N33): Short to Ground
P1228 - 35-00 - -
17634 - Fuel Injector for Cylinder 2 (N31): Short to Ground
P1226 - 35-00 - -
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-00 - -
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
17840 - Secondary Air Injection Solenoid Valve (N112): Open Circuit
P1432 - 35-00 - -
17695 - Boost Pressure Control Valve (N249): Open Circuit
P1287 - 35-00 - -
Readiness: 0110 1101
Friday,12,November,2010,18:52:38:20435
VCDS Version: Release 10.6.1
Data version: 20100831
trix
1200cc
Thanks Wayne
VCID: 1E3D2611B0C5
12 Faults Found:
P1636 - 35-00 - -
P1225 - 35-00 - -
P1227 - 35-00 - -
P1228 - 35-00 - -
P1226 - 35-00 - -
P1425 - 35-00 - -
P1548 - 35-00 - -
P1117 - 35-00 - -
P1435 - 35-00 - -
P1432 - 35-00 - -
P1287 - 35-00 - -
trix
1200cc
