my 2000 beetle hard to start after its been sitting and once it starts it runs very rough until it clears out then it runs fine I have had to put a little coolant in the morning and a little when I leave work. but no water in oil or coming out of the tailpipe. I have no leaks but I have noticed a lot of pressure on the coolant system and a greyish tint to the coolant. I flushed the system and put in g12 coolant and still the same gray tint to it.
Well,if that is what you think the problem is; start with some targeted testing with a compression or leak down tester. That would rule out any leaks in your system; if you have a scanner, scanning for codes might be a good idea as well. Let us know the results of your testing; keep us in the loop, as things progress.
My '99 will sometimes do the same thing if it hasn't been run for more than 2 or 3 days. It runs rough and the exhaust has a strong fuel smell. I'm quite sure the cause is sticking fuel injectors. I ran fuel injector cleaner through and changed fuel brands and it is much better.
i have had some misfire codes but cleared them out and the cel does not come on anymore it does it after its been sitting for at least 8 hours could it be a blown head gasket at the exhaust side because there seams to be a lot of pressure on the system
We are all speculating at this point; time to do some testing! Then, you will have "yes" or "no" answers and can continue in your troubleshooting process; get out there and jump in! Let us know how it goes! :)
