Trying to help my mom out she has a 05 beetle it's auto but when she driving tranny gos into 1st gear while shifter in drive
On the dash where it's say drive it turn into 1st like if she were to shift manual so she pull over
Puts it back in park then it drives regular. She told me before that she had problems with putting it in
Gear Some time she put it in drive the dash says neutral. I'm thinking it could be something with
The shift link or a sensor plz help thank you for your time
I would get the car scanned with a VW compatible scanner; post any trouble codes that come up. You might consider buying a cheap Vw compatible scanner; check amazon.com the Vgate vs450 is about $50 or go all the way to a factory level scan tool VCDS, from Ross Tech.
Typical issues seem to be failed/failing shift solinoids and worn valve bodies.
