It's the distance between the centerline of the wheel and the hub mounting surface.Yea idk what the offset is.. How do you figure that out?
Sent from my iPhone using Autoguide
The bolt pattern is correct and as long as the offset is within limits and you use the proper size tires then they shouldn't rub. The overall total diameter shouldn't change regardless if you are using 16 inch wheels or 20 inch wheels. with the 19's you will just have very little rubber and you will have to be very careful to avoid chuck holes and speed bumps because it will be a rough ride.Hmm I'll look into it. Plus if I put 19s on it won't it rub? Cause I got a deal on a set for 300 and they are 5x100 so I was thinking they would fit...
Dark gray is my favorite TS color. Looks kind I mean with the blacked out blinkers.Looks good! And you can also add / remove/ start over if you decide you want them smaller, larger, different angle etc. When I first did mine I went back and added some width after I checked to see how much 'scowl' they had. I didn't want my ride to look like it was stuck in mid-sneeze...
