I need to replace the forward o2 sensor on a 2004 VW beetle 2.0. I put it up on the hoist to find the sensor and found it on top of the exhaust manifold. How do you get this sensor off?????:confused: I don't see an easy way to get to it??? What size o2 sensor socket do I need?. This looks like a PITA to change.Hope someone can enlighten me on the best way to get this sensor replaced.
Bob
A little tough to see but this video should help:
https://www.youtube.com/watch?v=Clmu1Td0HkU
slightly different car but replacement is similar:
VWVortex.com - DIY - Replacing oxygen sensors
Lookup the correct Bosch 02 sensor here: (once you get the sensor; you can use it as a reference on which socket to get):
be sure to match the correct one with your engine code and get the "oe" not the "universal" version.
https://www.boschautoparts.com/en/auto
Testing and inspection info:
Volkswagen Workshop Manuals > New Beetle L4-2.0L (BEV) (2004) > Powertrain Management > Sensors and Switches - Powertrain Management > Sensors and Switches - Computers and Control Systems > Oxygen Sensor > Component Information > Testing and Inspecti
o2 sensors
Do they look anything like this picture? If so that is not the manifold I believe that is the CAT. Your local auto parts place have the specialty sockets for rental. It'll be a socket with a side missing to it. I rented the one from autozone and it came in a kit with 2-3 different size sockets. It can be done.
sensor
Nope mine is located up by the firewall. Thanks for the info.
then you might have to remove the windshield cowl, Y rain guard, wipers. pretty easy to remove I can take mine off in 10 minutes. you'll be surprised how much more room to work is by the firewall after you remove those items.
Keep It Real
Should be easy to get to those sensors, try using a 22mm or 7/8" open end wrench, if it resists you then soak it with penetrating oil.
