I am looking in to buying 19"rotiform BLQs 5x112 with a 35 offset and im lowered on fk coils. if it matters the car is an 04 beetle turbo s
All this & I can cook too
I am running privat netz 19's with a 40mm offset with stock ride height and they ride great. However the lug pattern is 5x100 so you will need adapters. Also look'into concentric rings - they are a must have and they are relatively cheap. If your car sits lower than stock you will need to work with it to find the right ride height.
Hope this helps,
Chef
my lug pattern is 5x100 but the wheels im looking at are 5x112 and with an adapter the overall offset of the wheels would be like 17 or something so im pretty sure they would poke way to much
