1 - 10 of 10 Posts
Slow acceleration on new beetle. New MAF. It has sloww acceleration till i push the gass all the way then it kinda downshifts and moves / accelerates faster.
I have my codes here . Please help i need this care to run the full 150 hp
I would start with a fresh scan and post any codes, code numbers not descriptions.
As for the maf; what is the part number and what brand did you buy? A high quality Bosch maf; is recommended, many aftermarket version do not perform correctly and cause drivability problems. Since, this is a variable you just changed; you might reinstall the old one and see if that helps your problem. Reading live data from the maf and comparing the two; would be a good idea.
Otherwise with 1.8T sluggish drivability and surging issues; tend be related to the boost control systems, not working correctly and boost/vacuum leaks, are usually the culprit. Diverter and other boost valves; are typically worn, in soft failure mode and it is recommended to try testing them using factory service procedures. Read more here:
http://newbeetle.org/forums/1-8-lit...sch.html#/forumsite/20963/topics/50602?page=1
Here is another thread with similar issues:
http://newbeetle.org/forums/showthread.php?t=127410
Scan the car, post up the codes, swap the maf and check out your boost valves and any vacuum leaks. We can go from there... Thanks!
My codes,
These are my codes after cleaning throttle body. new BOSCHE MAF New sparkplugs and new top cover engine gasket seals.
You have a TON of codes! How long; has it been, since you did a scan? If it has been a long time; these could have built up over the years, you could clear them and see what comes back. You have quite a few codes; that are directly related to the boost control system, these could be directly related to your sluggish drivability problem. At a beginning point; I would make sure, your charging system is working correctly (e.g. battery, alternator, wiring, etc.). If you have a low voltage issue; it can cause, all the computers to freak out and throw ton of codes, as they cannot work correctly with low voltage.
16502/P0118/000280 - Ross-Tech Wiki
17965/P1557/005463 - Ross-Tech Wiki
18010/P1602/005634 - Ross-Tech Wiki
P1357 VOLKSWAGEN Ignition Circuit Cylinder 1 Short to Ground | AutoCodes
P1366 VOLKSWAGEN Cylinder 4 Ignition Circuit Short to Ground | AutoCodes
P1360 VOLKSWAGEN Ignition Circuit Cylinder 2 Short to Ground | AutoCodes
16795/P0411/001041 - Ross-Tech Wiki
16622/P0238/000568 - Ross-Tech Wiki
P1363 VOLKSWAGEN Cylinder 3 Ignition Circuit Short to Ground | AutoCodes
P1225 VOLKSWAGEN Injector Circuit Cylinder 1 Short To Ground | AutoCodes
P1227 VOLKSWAGEN Injector Circuit Cylinder 3 Short To Ground | AutoCodes
http://wiki.ross-tech.com/wiki/index.php/17843/P1435/005173
17829/P1421/005153 - Ross-Tech Wiki
P1289 VOLKSWAGEN Turbocharger Bypass Valve Short To Ground | AutoCodes
18057/P1649/005705 - Ross-Tech Wiki
For the boost related valves; you could test them and make sure, you do not have any boost leaks or disconnected hoses.
Here are the service manual pages; to test the different valves: (N75, N249, etc.)
locations:
http://workshop-manuals.com/volkswa...ntrol_module/component_information/locations/
testing:
http://workshop-manuals.com/volkswa...turbocharger/component_information/locations/
Ok, so which boost trouble code is it? Please, post the codes; not descriptions, this removes any possible confusion and we are on the same page, thanks. Then, I would start looking at the definition; on the ross tech wiki and start testing that problem/valve, based on the service manual procedures.
1 - 10 of 10 Posts
