I recommend you look at 2008 to 2010 Beetle Convertibles for your College bound daughter.
You should be able to find one with under 80,000 miles for less than $11,000
The 2.5L i5 engine in the 08-10 was bullet proof and has a timing chain so no need to worry about a timing belt.
The automatic transmission in the 08-10 was the least prone to premature failure not to say it still does not occur.
Find a convertible with a manual top, the electric/hydraulic top on the New Beetle is problematic across the model line,
Rear glass is an issue with all convertible tops with glass windows.
A proper replacement top will set you back around $2,000 and the top will have a life time warrantee on the glass.
I own several Beetles including a 2008 Beetle Convertible S I bought for my wife. Our Beetle is an automatic with a manual top it just turned 70K miles. The dealer wanted 12K for it but I took it off the lot last August for 10.5K as it needed a top due to the glass issue.
Best of luck
Best of luck
