1 - 12 of 12 Posts
hello all im new to this site looking tet some help from fellow vw owners. I have a 2002 vw beetle 2.0l motor 5 speed transmission. im having an issue where the car will not turn over. all the dash lights radio windows horn lights etc works but when I turn the car to start theres absolutely nothing. the fuel pump humms, but not getting any noise from starter engagement. any help? I check fuses bypassed the clutch safetys to see if that was issue and still nothing:confused:
1999 GLS 2.0 m/t
Did you try a jump start? All of the things you listed only require a minimum of amperage compared to the draw of the starter motor
Have you confirmed; that you have a full charge at the battery? Have you checked all the fuses and relays? Sometimes, the electrical portion of the starter switch will fail, causing a no start condition (starter motor will not spin). They are cheap and available at most auto parts stores; you could also have the starter bench tested as well.
More info; on the replacement of the ignition switch:
http://newbeetle.org/forums/1-8-liter-turbo/59181-ignition-switch-replacement-diy.html
starting section of the service manual:
http://workshop-manuals.com/volkswa...switch_relay/component_information/locations/
Just check all the basics; before tearing things apart, keep it simple to start with!
Sounds like it's something electrical, starter, solenoid, fuse or relay. If the battery had voltage but no amperage you would at lest get a clicking, unless it was super dead and then you probably wouldn't have lights or windows working.
Just this week I had the same problem. I was able to start with booster cables. I let the car sit for 6 hrs and tried again. No start. Booster cables didn't help. I pulled the battery (group 48 oem dealer 72aH) and charged it overnight on a Schumacher SC8000a charger. The charger said 100% charge when I removed it. I installed the batter and got a extremely slow turnover and then a series of clicks. I took the battery back out and put it on the charger. I was convinced it was my starter that was weak, since I have a tdi and the battery was only 2yrs1mo old. It was a dealer oem battery. I ordered a starter and a 109 relay from idparts.com. Meanwhile I got a Dayton 4Z581 100A battery load tester. I recharged the battery. After full charge, I let it rest for 2 hours. Then I used the load tester and had over 13A hooked up, when I applied the load for about 8 seconds it dropped to 8A. BAD BATTERY!!! I went out and bought and installed a 94R battery! That's a big battery and since I don't have a battery box, it fit perfectly!
Moral of the story: I misdiagnosed the starter as faulty. It was the battery! Vehicle Technology Auto part Car Engine
Discussion Starter · #7 ·
Volkswagen Workshop Manuals > New Beetle GLS L4-2.0L (AZG) (2002) > Starting and Charging > Starting System > Clutch Switch Relay > Component Information > Locations
i have tried a new off the shelf battery and it does the same thing. ill have to pull the stater and see if its the issue. I am getting power from battery to starter which wire should I test while turning over to see if it getting power?
Discussion Starter · #8 ·
Moral of the story: I misdiagnosed the starter as faulty. It was the battery! View attachment 178762
tried a brand new battery and have same issue
Discussion Starter · #10 ·
Have you out 12v directly to the starter.
yes it got 12 volt to starter. if I touch test light on other parts of the starter rather then the direct battery to starter wire I have no power to them do I need to pull the clip looking plug and crank to test that one?
I mean starter directly to the battery. You can have 12V but low current. I would disconnect the battery and starter cables and use jumper cables straight to the starter and see if it tried to turn over. Be careful. You need a second person for safety. Won't hurt to try. Divide and conquer.
Discussion Starter · #12 ·
checked voltage at battery 12.7 volts
checked voltage at starter only getting 7 volts from the ignition to the starter from the plastic clip prong. tried jumping the starter and nothing, so im leaning toward bad selonoid?
1 - 12 of 12 Posts
