I just installed a new timing belt, tensioner, acc belt, and water pump.
Now with the car idling I can hear an intermittent rattle from around the oil pan.
I checked and triple checked the timing. The tensioner is set correctly from what I can tell and everything is torqued to spec.
The old water pump broke as it came out but I think I got all the bits of it out. The new one spins smooth as it should.
I put a screw driver the the head with the car running and didn't hear the rattle so I'm 90% its not valves.
There was no rattle before the new belt! HELP!
