Ok, so I have an 02 NB Turbo S with the stock 225/45/17 setup. The tires are old and it's time to upgrade. When I do upgrade I want my car to have a meaner look without sacrificing the smoothness of the ride, and without having tires big enough to scuff wheel wells. I was considering stepping down to 16s and getting a bigger tire, but I've decided to either keep my 17s or to upgrade to 18". But if I could get a beefy set of tires while keeping the 17" wheels, that would be superb.
These are the options...and I've used a tire size calculator that I found in another thread, (the link is below)
Tire size calculator
to calculate the speedometer reading, sidewall, etc., but I will need some help on a few things. I've decided to go with either Kumho Ecsta LX Platinum tires or Federal Formoza Fd2s:
I. 17" Options:
1)235/45/17 1.4% speedometer reading too slow
This here would probably be the ideal tire & wheel size for me, but Formoza's specs sheet said the standard rim width is 8.0, and best for wheels between 7.5 and 8.5mm. My current wheels are 17 X 7.0, so my guess is this may not work..?
Does anyone have any experience with this size, and if so how is it?
2)225/50/17 3.5% Speedometer reading too slow
Given the circumstance that I can have the gearing of the trans recalibrated and that it wouldn't be too expensive, I'd go with this next if I couldn't get the 235/45/17 setup.
II. 18" Options:
First off, will upgrading from 17" to 18" wheels automatically reduce the smoothness of the ride if I stayed with the same tire dimensions? (225/45) If the answer is yes, then most likely I won't go there...since upgrading the height percentage may make the tires scrape the wheel wells. Anybody have experience with both 17" and 18" tires? (Note: I'm aware that they gear ratios would have to be recalibrated, I just want to know about ride quality vs 17")
1) 225/55/18 4.0% Speedometer too slow
2)235/40/18 1.7% Speedometer too slow
Now this is the ideal size that I would love to have if I did decide to upgrade to 18" Wheels (unfortunately, it sucks that Formoza doesn't have this size...so I hope the 17"s pull through
III. 16" Options:
I know I said I wouldn't consider smaller wheels, but just in case it doesn't look too bad...here's what I'm thinking..
1) 205/55/16 0.4% Speedometer too fast
2) 215/55/16 1.4% Speedometer too slow
This is the ideal setup for this size wheel to me.
So these are the options that I'm faced with. I'm looking for a very quiet ride, with a meaner looker tire than my stock 225/45/17 setup. Please help! Would really appreciate any/all input, i've been mulling over these for a few days and need personal experienced opinions to help me make my decision. Thanks!
I. 17" Options:
II. 18" Options:
III. 16" Options:
