1 - 10 of 10 Posts
Hey there everyone,
I have a 2005 New Beetle and I got it used with only 37,xxx miles on it. As expected little things have came up. The check engine light came on the second day I had it, so I took it to a friend of mine that is familiar with VW. He had me take it to AutoZone to scan for codes. The code p2196 came up, I tried looking on that Ross wiki site but can't find it on there. If you guys can help point me in the right direction that'd be great. The guy at autozone told me to give fuel system treatment & lube a try and see if that may resolve the problem. Any tips will be appreciated. Thanks!
Discussion Starter · #2 ·
To further elaborate on the situation, this is what the print out from Autozone reads:
Definiton - Heated o2 sensor - Bank 1 Sensor 1 sensor signal suck rich
Explanation: Blocked exhaust
Probable Cause -
1) High fuel pressure
2) Failed fuel injector
3) Failed fuel pressure regulator
Hopefully someone can shine some light on this issue
Thanks.
P2196 Volkswagen
P2196 Volkswagen - O2 Sensor Signal Stuck Rich Bank 1 Sensor 1
PDF Share Code 0 P2196 Volkswagen Comments | Add Comment
Possible causes
- Faulty Front Heated Oxygen Sensor Bank 1
- Front Heated Oxygen Sensor Bank 1 harness is open or shorted
- Front Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Vacuums leaks
What does this mean? What does this mean?
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel Consumption
P2196 Volkswagen Description
The front heated oxygen sensor (or O2 sensor 1) is placed into the exhaust manifold. It detects the amount of oxygen in the exhaust gas compared to the outside air. The heated oxygen sensor 1 has a closed-end tube made of ceramic zirconia. The zirconia generates voltage from approximately 1V in richer conditions to 0V in leaner conditions. The heated oxygen sensor 1 signal is sent to the Engine Control Module (ECM). The ECM adjusts the injection pulse duration to achieve the ideal air-fuel ratio. The ideal air-fuel ratio occurs near the radical change from 1V to 0V.
To figure out what is going on; you need to start testing things and see what is going on. In your case; starting with the basics: your 02 sensor maybe a issue or you maybe having a fuel pressure problem. The (bank 1; sensor 1, the first 02 sensor after the engine), can be "seen" with a scanner capable of showing "live data"; to note its activity or if it is working at all. A scan tool like this; many times, can be rented from a auto parts store or purchased online, from places like amazon.com. There are many VW specific scan tools; that can do this, in the $75 and up range. Other generic scan tools; may be able to do this as well but cannot read many Volkswagen specific trouble codes. The high end vw factory level scan tool; is VCDS by Ross Tech but there are many cheaper versions as well.
The fuel pressure; can be tested, using a fuel pressure test kit. These can be purchased or rented; from most auto parts stores.
Testing info and step by step procedures; are shown online for free here:
Volkswagen Workshop Manuals
Let us know; how you want to proceed, specifically: do you want to repair it yourself or take it to a professional? After, you decide what direction you want to go; we can go from there.
Thanks for the quick reply Billy, I apologize for the double post. But I do want to fix this myself I've never been a firm believer in taking it to a professional unless I absolutely need to. With that being said, I'll have to find a VW specific scan tool and see if that sensor is actually working in the first place. Then, if that all checks out I'll proceed with the fuel pressure test. I do have a friend that is very familiar with VW as he owns a Passat so I'll be going to him for advice step by step as I'm not that mechanically inclined lol. Any other recommendations you may have?
It's best to have the car on a lift at a shop and have the whole exhaust system, examined. You could do this at home but you would need to jack it up and put it on jack stands.
1 - 10 of 10 Posts
