Just bought this Bug and almost everything works!!!
Radio did on test drive, loaded up the multi-changer with one disc to see if this works and now no radio etc. Nothing on the screen i.e. "safe mode" switch lights on and the Radio controls illuminate red and flash??? I have all the handbooks but the radio code strip has been removed .....obviously put in a safe place by the original owner hmmm! Battery fine, not checked the fuse yet because if I remove this I could be locked out....if I'm not already :p
I've heard this is not unusual, how do I proceed guys???
Lady Toad
EBay to the rescue! Yes the info given was most unfortunately for my pocket spot on! all fuses were fine .......something died internally in the unit:mad:
Odd as I've had several Blaupunkt units in cars over the years and found them very reliable..... hey ho!
Hi Billymade,
Yes checked, changed and tested both original and replacement fuses both were working and showing power??? Bought and fitted a tested O.E unit from ebay.... sod to fit with the thick connector cable.... but now have full audio and a 6 disc changer working as it should:)
