Im getting a 99 VW GLS Beetle for my son. It gets delivered by a friend on Feb 2nd. We need to get wheels and tires as the owner wants to keep his winter set.
We want style but on the cheap. We found a set of new ICW Racing BANSHEE 18" wheels. The part I am unfamiliar is the offset.
Here are the specs: 215B Banshee: 18X7.5, 5X100 / 5X4.50, OS: +42, BS: 5.90-Satin Black
The site, where we found them, only talks about is the bolt pattern.
Will theses work?
Side question: Run flat tires or not?
Newbie wheel question. Max offset on an 18" wheel?
Yes it will fit, you can find an app or a site where you can compare the actual wheels with the new ones and they show you a graph of the both tires...
Personally I use "Wheel will fit" on IPhone
Sent from outerspace!
Thanks for the information. The owner just removed the tires from the wheels and put on older tires. We will keep this for future use.
