I have a 2001 1.8 turbo beetle. Last year my a/c worked fine this summer not so much i'm a bit confused it blows hot air, will not take
Refrigerant, compressor does not engage, one of two fans is working, and the fuse (30amp) that is on top of battery keeps blowing out.Where do I start to repair my A/C.Thank you
The fact that one fan seems to be possibly bad and a fuse is blowing; may be a indicator they are possibly interrelated? Here is a great place, to start troubleshooting yiur fans:
https://www.newbeetle.org/forums/qu...oming-here-check-your-fans.html#/topics/43260
You could disconnect the fans one by one and see if the fuse stops blowong out, which could indicate the fans might be a problem? Check out the link; for more troubleshooting info. You definitely, want to get your cooling fans working correctly and then, you can go through testing the a/c system.
