Okay so here it is. I went to try and adjust my timing of my fuel pump the other day. The experts younger brother was the only one who could work on it. We ended up adjusting the timing which looked to be a bit advanced. Needless to say it three hours with many trys to adjust it with parameters outside of the graph on the vcds. We where adjusting the timing not the fuel pump which is what I heard should be done. I was told this was how to adjust it. Well we got it tuned in and the car seemed to run fine. Even slightly better. About 30 miles later though some thing happened. I lost power though i lost it after coming down a rather large mountain in Guatemala using third gear at 3000 rpms to slow me down so I would not burn out the brakes. After I went to a old city with cobble stone streets for a few miles and shut the car off. When returning home I went over one speed bump and just a tiny scrap. Upon accelerating I noticed black exhaust for a few seconds. The highway had just started and I noticed I had no pick up though no check engine lights are on.
Can using the engine compression to maintain speed cause an issue?
Could the belt have loosed with the cobble stone?
I live in Guatemala about a mile up almost and it is 70 to 80 every day. My injection torsion value was reading 1.4 with the timing adjusted to right above the line, though I am not sure my engine was up to temp at that point though we did let it run periodically. I would imagine that my torsion value (range 1.1 to 4.5) should be set around 4 with the altitude and heat. The timing was advanced to about 70 percent of the way of the graph on the vcds reading to begin with. Could it be that I am just running to rich? I had to start on a hill and the only reason I did not stale is I road the clutch for a few seconds with the pedal far down.
Any help would be appreciated. I found a place that sells a cable though can I see what is up with vcds lite?
