1 - 14 of 14 Posts
Discussion Starter · #2 ·
I found this fault code 馃槙
Chassis Type: 9C - VW New Beetle (1999 > 2010)
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
Mileage: 165600km-102899miles
Address 01: Engine Labels: 06A-906-032-AWD.lbl
Part No: 06A 906 032 CK
Component: 1.8l 5VT NB HS 3099
Coding: 00001
Shop #: WSC 00066
VCID: 69E1FA2F1333FFCCB5-FFFE
1 Fault Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 35-00 - Incor. Correlation
Readiness: 0010 1000
You might run the speedo cluster output test; which activates all the lights that can be illuminated in the speedo cluster:
We have seen, people desolder a light on the circuit board or cover it with tape; so you won't see it illuminate, a common trick, when selling a used car with a unresolved problem.
As i said, we have seen the leds on the internal circuit board, desoldered or ripped off and then, tape covering the light, inside, between the light, then speedo face itself. This way it is hidden and you cannot see it being on.
My daughters beetle has an immo delete so the light always flashes. I removed the speedo, partially separated it and placed a piece of black electric tape over the immo light. Even when I look for it knowing it鈥檚 there I can鈥檛 see it.
Check the ross tech link for testing checks; you might check for cam chain mvb for chain stretch, if the engine supports it. Is the head noisy? Chains stretch and eventually the tensioner wears out and fails.
1 - 14 of 14 Posts
