Thank you. It was the ignition switch or a short. A wire and some plastic is melted to one of the connectors. I've replaced the switch and will run it for a week with all the covers off. It will give me some time to clean the goo-scratches, repaint, then assemble.
Not happy with Haynes. Their manual says to remove top and bottom cover of the steering column, but to remove the bottom cover, one must remove the steering wheel. To remove the steering wheel, one must remove the instrument cluster. When I was unable and frustrated with releasing the spring clips to remove the airbag, I took off the steering column adjustment "pedal" and the bottom cover slipped right off. Grrrrr. Half-day wasted.
