Hi Folks:
The battery in my 2006 TDI is draining after sitting 2 days unused. I checked:
Battery is good at 12.65 V
Voltage when charging at 14.6 V
Charging cable is ok.
Parasitic drain checks performed with doors locked (but door open). Key off.
No drain between Battery and negative lead.
All fuses (incl under hood) checked with multi meter and no significant drain (per Humble Mechanic instructions) detected.
Ross Tech shows intermitent voltage issues with driver and passenger door module (has done that since I owned the vehicle. The only issue is the loss of the remote for the door lock.
Starting to go nuts! Any thoughts or suggestions?
Thanks, Folks!
Mike
Thanks, Folks!
Mike
