SOLD IN THE SPRING OF '08
My car in its final form before I sold it
Old Look c. 2007
Old Look c. 2005
Pro Pics courtesy of Jeff Wilson (www.jw-photo-com)
Here are my mods as of Friday, March 28, 2008.
Cosmetic Mods:
*18x8.5 BBS CH wheels(summer)
*H&R 10mm spacers (rear)
*Clear front turn signals
*European Blue/White badges
*Turbo script badge on hatch
*GPA Aluminum trim rings
*Forge Motorsport stubby antenna
*Audi TT pedals (auto)
*Turbo S dead pedal
*2-tone interior (black leather seating, tan carpeting)
*Custom boost gauge pod
*Custom Front Valance by John @ Eurojet
*Home made All-Red tail lights
Performance Mods:
*Black Forest Industries Stg.2 Polyurethane dogbone mount bushings
*Techtonics Tuning 2.5" cat-back
*No-Name 2.5" downpipe with high-flow cat
*Dahlback Diverter Valve (polished)
*Braided Stainless Brake Lines
*Hawk HPS Brake Pads
*Eibach Pro-Kit springs
*Bilstein Sport Shocks/Struts
*Neuspeed 25mm front swaybar
*O-bar rear swaybar
*225-40-18 Kumho SPT tires
*Turbo S fender liner
*GIAC 1.0-bar chip
*VF Engineering Engine Mounts
*Short-Ram intake
*Forge Motorsport Turbo Inlet Hose/pipe
*Newsouth Performance intake manifold phenolic gasket (not installed)
*"Signal Scoop" custom air scoop and turn signal
*TyrolSport New Beetle Upgraded Side-Mount Intercooler (UGSMIC) (first production unit ever)
*Raxles High-Performance Axles
*IPT-Built O1M 4-speed Automatic Transmission:
-Heat-Treated Internals (Strength)
-More and More Aggressive Clutches (better power holding)
-Re-worked Valve Body (firmer, faster shifts)
-Fluidyne External Trans Fluid Cooler
*R32 Lower Control Arm Bushings
*Self-Built Porsche Boxster front brakes http://www.newbeetle.org/forums/showthread.php?t=24373
Track & Autocross Setup:
*17"x7.5" et35 SSR Competitions (12.7lbs a piece) w.5mm spacers to clear brakes
*235-40-17 Bridgestone Potenza RE-01R
Other Mods:
*Dieselgeek aluminum skidplate (same as Beetle 'vert)
*European light switch
*Rear Foglight
*Hella Micro DE Fog Lights (waiting to be installed)
*Bestdubs.com 6000K HID kit
Accolades (in chronological order):
3rd place (NB Modified) 2005 Fall VW Show & Go
1st place (NB Modified) 2006 Spring VW Show & Go
1st place (Best New Beetle) 2006 Dub & Grub
3rd place (NB Modified) 2007 Spring VW Show & Go
1st place (Best New Beetle) 2007 Dub & Grub
Here is a link to my page on the old NB.org forum
http://forums.newbeetle.org/showthread.php?threadid=35479
Old Look c. 2007
Old Look c. 2005
Cosmetic Mods:
*Turbo S dead pedal
Performance Mods:
*O-bar rear swaybar
*GIAC 1.0-bar chip
*Short-Ram intake
Other Mods:
*Rear Foglight
