The heater in my 02 Turbo S won't get warm at all. I mean it's barely tepid. I researched the issue on the site here and determined it was most likely a thermostat failure, probably a partially opening thermostat. I got a new thermostat, housing and also picked up a new coolant temp sensor just to be safe. I drained the coolant, replaced the sensor and the thermostat and refilled the coolant, being careful to purge the system of air. I've been through the procedure a number of times on other vehicles so the approach isn't new to me. And after running the engine for over twenty minutes the heater is still barely warm. I can feel the lower rad hose get hot when the thermostat opens, but the fans never kick on and the heat just won't get hot. The car never runs hot. I also checked the 40 amp fuse to the fans and it is fine.
So, any ideas or input?
Also, on a related note I have to say that I am impressed with the design of the cooling system. When I drained the coolant I was expecting it to be dirtied but it is spotless. No discoloration at all. This is the first time I have worked with the cooling system since I bought the car almost two years ago, so even if the previous owner changed the coolant right before I bought it, it still looks very clean given the amount of use.
