P0102 Mass Air Flow (MAF) Circuit Low Input
P1542 Throttle Actuation Potentiometer Range/Performance
P1171 Throttle Actuation Potentiometer Signal 2 Range/Performance
P1559 Idle Speed Control Throttle Position Adaptation Malfunction
P1565 Idle Speed Control Throttle Position lower limit not attained
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0139 Oxygen Sensor Circuit Slow Response (Bank1, Sensor2)
P1198 Oxygen Sensor Heater Circuit,Bank1-Sensor2 Electrical Malfunction
P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0441 Evaporative Emission Control System Incorrect Purge Flow
I just ordered a new O2 sensor and 2 new Knock Senors. What else do I need?
Wow, not sure I would buy all of this at once.
So, assuming you have not cleared any codes yet, suggest you get Freeze Frame data and post it back here.
The clear codes and drive car and see what happens. Assume the car is drivable?
The when CEL comes back on, immediately check codes and Freeze Frame data and document.
This almost sounds like a grounding/electrical problem on the surface??
