I have read a bunch on the mirrors, mine don't move, I replaced the switch, checked fuse, ... I pulled the mirror glass off and it's seems the motor mechanism is very stiff. I sprayed it with wd40 and it got stiffer? Do these mirrors have a history of this. I'm a new beetle owner? 2000 GLS
MAYBE SOME GREASE? can't find these little motors for sale, they come right out
Any help would be appreciated
Have you checked to see if there is power at the motor?
WD-40
"WD-40 was developed by the military in the 50s as a rust preventative solvent and de-greaser to protect missile parts. It quickly became a household item when people discovered it had thousands of other uses as a cleaner, rust-prevention agent, squeak-stopper and more. It also works wonders as a light lubricant on small items like hinges, locks, and toys.
Bicycle chains, on the other hand, are far too heavy and fast-moving for the lubricating power of WD-40 to have any effect at all. As a matter of fact, WD-40 will actually strip away any existing lubricant and leave your drivetrain dry – metal on metal. Basically, spraying this stuff on your chain is worse than using no lubricant at all!"
Bottom line - Don't use WD-40 around your car, it is a worthless product for the purpose of anything on a car you think it is good for.
But, if you are just hell bent on using that can of WD-40 for something, here is a list of reported good purposes:
Attract fish. When sprayed on fishing bait, WD-40 covers up the scent of human hands on the bait to better lure fish, according to USA Today. The WD-40 Company receives hundreds of letters from consumers confirming this use, but prefers not to promote WD-40 as a fishing lure since the petroleum-based product could potentially pollute rivers and streams, damaging the ecosystem.
Cure Mange. While spraying a dog with WD-40 gets rid of parasitic mites, according to USA Today, the WD-40 Company, feeling that the potential misuse of the product is too great, refuses to condone using WD-40 to cure mange on animals.
Prevent squirrels from climbing into a birdhouse. Spray WD-40 on the metal pole or wires.
Remove a ring stuck on a finger. Several medical journals claim that WD-40 is the perfect cure for a toe stuck in the bathtub faucet, a finger stuck in soda bottle, or a ring stuck on a finger.
Remove chewing gum, crayon, tar, and Silly Putty from most surfaces. Spray on WD-40, wait, and wipe.
Clean decorative snow from windows. Spray windows with WD-40 before spraying with artificial snow so the decorative spray will wipe off easier.
Prevent dead insects from sticking to your car. Spray WD-40 on the hood and grill so you can wipe bugs off easily without damaging the finish.
Make hangers glide over a clothes rod. Spray WD-40 on the clothes rod so hangers can be pushed back and forth easily.
Clean clogged spray paint can nozzles. Remove the nozzles from the spray paint can and the WD-40 can, place the nozzle from the spray paint can on the WD-40 can, give it a couple of quick squirts, and replace both nozzles.
Remove oil spots from driveways. Spray with WD-40, wait, then blot. The mineral spirits and other petroleum distillates in WD 40 work as a curing agent.
Thread electrical wire through conduits. Spray WD-40 on the electrical wire to help it glide through winding conduits.
Prevent grass clippings from clogging up a lawn mower. Spray WD-40 on the underside of lawn mower housing and blade before cutting the grass.
Clean sap from gardening equipment. Spray with WD-40, wait, and wipe clean.
Prevent mud and clay build-up on bicycles. Spray the bicycle with a thin coat of WD-40.
Remove baked-on food from a cookie pan. Spray WD-40 on cookie pan and wipe clean. Then wash with soap and water.
Remove dirt and grime from barbecue grills. Remove the grill from the barbecue, spray with WD-40, wait, and wipe clean. Then wash with soap and water.
Remove chewing gum from the bottom of a shoe or sneaker. Spray on WD-40, wait, and pull the gum free.
Keep dogs, maggots, and flies out of trash cans. Coat the trash cans with a thin layer of WD-40.
Take squeaks out of new shoes. Spray WD-40 into the leather and shine.
Remove grease stains from linen. Spray WD-40 directly to the stain, rub it in, let is soak for a few minutes, then wash through a regular cycle.
Take squeaks out of a box spring mattress. Remove the fabric covering the bottom of the box spring mattress (by simply removing the staples), and spray the springs with WD-40. Staple the fabric covering back in place with a staple gun.
Polish wood furniture. Spray WD-40 on a cloth and wipe.
Clean crayon from a blackboard. Spray WD-40 on the crayon marks, let soak for 10 minutes, then blot clean with a cloth.
Free a tongue stuck to frozen metal in winter. Spray WD-40 on the metal around the tongue.
The last one is my favorite!
MORAV
You've lost me :lol:
