Hello everyone. I have a 03 beetle with the 2.0 and im having some issues. It has a p-304 code. I had replaced the wires due to arching against the head and plugs.
It has set a couple of times and seems to do it around 70-75 mph and tach around 3500 or so. The light will begin to flash and when i slow down it has a dead skip. Whats weird is if i shut the car off and start it back up it runs perfectly fine but obviously the light remains on. I tried to duplicate the issue and so far cannot after 70 miles.(very intermitent) I ohmed the injector on #4 and it has the same values as the others. I removed the coilpack which is one piece, and it looks fine. im thinking there is a short under heavy load thats causing these? Any suggestions?
Thanks in advance
Dan
Thanks in advance
Dan
