I have an 2001 Volkswagen Jetta 1.8t and I've been having this code come up for around 3 months. I've had the Mass Air Flow Sensor replaced (with an aftermarket and an OEM one), I've had the engine smoke tested and had the 2 vacuum leaks fixed (not sure where,sorry), I had the pre-catalytic O2 sensor replaced (again OEM one, and have another ordered shop said could be a "bad one") and had the catalytic converter replaced as well and still have not had any luck of fixing the problem.
The ca has been getting very poor gas mileage, poor acceleration, and was stalling on the highway and while driving in the city, it has a very rough idle (it sits between 8 and 9 hundreds). I've only put the 93 or higher rated fuel in the car and do my best to keep up on the maintenance. Any other thought and/or ideas would be greatly appreciated.
