First let me say I'm a Mazda guy, so this is almost like a different continent for me. I have looked at the numerous other threads on the P0171 and the majority seem to be on turbo cars. I have a 2008 Beetle Convertible 2.5 BPS automatic. I bought it with front damage and rebuilt it for my daughter. It had a number of codes when I fininshed so I have thrown a boatload of parts and now am down to just the repeated P0171 Fuel Trim Bank 1: System Too Lean. I have done the following:
1. Replaced the PCV with the Dorman Kit
2. New fuel filter
3. New Bosch MAF
4. New Bosch O2 sensor
5. Sprayed everything I could spray with carb cleaner with no change.
6. Fuel pressure at idle is 44lbs
7. One not is coolant temp is showing 160-170, even in most stop and go traffic.
Drivability is still very good. Noisy at cold start, but I've read that's normal?
Once I clear the code, on cold start the STFT goes 20+, coming down just a bit after 160 degrees. LTFT pushes up to 18 or so then will move up to 20 then 20+ and it throws the P0171 before I can get Secondary Air and EVAP readiness.
I have an appointment to get a smoke test done as I have nothing left.
I welcome anything else people have done to fix this. Thanks in advance for your help.
2. New fuel filter
3. New Bosch MAF
