21 - 27 of 27 Posts
For live data, screen captures; are less useful, the info, needed would be the highest they are at. + or - 10% is considered; in the "normal" range. When, things go way out of spec; then, you get the lean trouble code.
2006 Cabrio, Platinum Gray, 2.5L BPS, Automatic
What about going to accelerate and it's not in gear. Like it got knocked into neutral. Let off the pedal and it goes in? This car only has 55k. Is it as simple as low on fluid?
Here is how it is done with vcds:
I'm not familiar or use obdeeleven, you might check their forums:
This video shows live data channels but oddly, they do not describe what they are?
Maybe other obdeleven users can chime in and help?
21 - 27 of 27 Posts
