I have a '01 Beetle Sport with a 1.8T. I am getting a P0171 code. I repaired the cracked power brake booster line and the cracked/soft PCV line. I have checked for other vacuum leaks with a hose attached to a stethiscope. The only thing that shows up is a pressure leak where the PCV line attaches to the lower block (I can hear pulsing from this area). Would this be enough to set a P0171 code?
Anything, is possible, any vacuum leaks should be repaired and bad hoses, parts replaced (then, after the repairs; recheck your fuel trim levels); do you have a scan tool and can you view live data?
As noted, in the Ross Tech Wiki; there is a long list of possibilities, have you checked your fuel trims (+ or - 10% being considered in the normal range), MAF readings and done a fuel pressure test? These are defintiely; the common causes and tests can be done yourself, to rule these possibilities off of your list (process of elimination):
New Beetle GLS L4-1.8L Turbo (AWV) (2001) > Volkswagen Workshop Service and Repair Manuals > Maintenance | Tune-up and Engine Performance Checks | Fuel Pressure | System Information | Specifications | Pressure, Vacuum and Temperature Specifications
workshop-manuals.com
Vacuum leaks are common on the 1.8T; a smoke test or other methods can be a way to find leaks. At almost 19 years old; we are seeing, many 1.8T new beetle's with weak fuel pumps and they can throw a lean code but not much else (a bad fuel pump; will not throw a code, aside from a lean code or if the fuel pump relay is failing, one for that).
Most auto parts stores; will have a fuel pressure test kit, available for free rental and it is not hard to perform this test. Give us some more info; on the history of the car, how it is running and the results of your repairs, testing... we can go from there. Thanks.
Thanks for the response. I had a better look at the crankcase breather elbow and can see that it is cracked, so I'll order a new one. While I'm waiting, I'll check the fuel pressure and the fuel trim numbers. (I was going to check the fuel trim last week. but I didn't feel that it would be safe to looking at the scanner while driving in bad weather.)
As far as how the car runs, it seems to run perfect. I just get the CEL that turns on. I can clear the code (P0171 is the only fault) and it will come back within 2 days. As far as previous history, I'm afraid that I'm not much help there. I just bought the car last winter, as a wreck, and just put it on the road this spring.
Thanks again and I'll post more results when I get them.
OK, here are some results: I replaced the cracked crankcase vent elbow, as well as the dipstick tube that broke while replacing the elbow. I hooked up my scanner and drove it. A test of the Mass Airflow sensor(WOT @ redline) showed approx. 135g/s after I did the math to convert it from lbs/min that my scanner reads(which seems good). After driving approx. 50 miles home, my Long Term Fuel Trim had crept up to 21.3%. Short Term Fuel Trim was fluxuating around -3% to +10% depending on weather I was accelerating, decelerating or holding steady. I hooked up a fuel pressure guage today and had 35psi at an idle. The pressure would respond to vacuum changes when I reved the engine(psi raised when opening the throttle, dropped when throttle was released (which seems good).
My next step is to build a smoke tester and see what my results are.
Related Threads
VW Beetle Forum
979.7K posts
73.9K members
Since 2005
The New Beetle forum, come in and join our discussions on the new Volkswagen Beetle. Talk about modifications, performance and color choices.
