Trying to make that dastardly light on my dash go out... This is a 99 NB 2.0 AEG engine 5 speed manual.
Have MIL/CEL checking codes with vag com reveals a 16556/p0172 rich code but no others, engine idles fine and drives with no noticeable symptoms. I Did have a few vacuum leaks but I believe all have been fixed now, but maybe not. Block 032 o2 trim readings are -18% and 11.8%, ran some injector cleaner through at the last fillup with no change. Also ran a WOT 2nd gear maf test. Highest level recorded was 73.96 g/s from memory it seems the g/s should be closer to 90? Thanks in advance for any help. I hate to replace parts yet without some certainty that they are indeed bad.
scan info below
Chassis Type: 9C - VW Beetle
Scan: 01,02,03,08,15,17,19,26,35,46,54,56
Address 01: Engine
Controller: 06A 906 018 JE
Component: MOTRONIC M5.9.2 HS V01
Coding: 00000
Shop #: WSC 00066
1 Fault Found:
16556 - Fuel Trim: System Too Rich: Bank 1
P0172 - 35-00 - -
Readiness: 0000 0001
scan info below
Address 01: Engine
Coding: 00000
Shop #: WSC 00066
1 Fault Found:
P0172 - 35-00 - -
