My MIL light came on yesterday, and had Autozone run the scans and got P0300 & P0302. My question is which spark plug or coil is the #2 cylinder, how hard are they to change out? Does anybody have any diagrams or pictures? This is a 2001 1.8 turbo sport. The car is running great but the light is on.
180 Degrees out of faze
The number 2 plug is the second from the left. Before checking the plug, take a look at the coil pack. You maybe covered by the recall. Check with your dealer.
a.k.a. porkchopzz4
And if the coil is good, a bad plug wire is more likely than a bad plug - but I'd replace wires and plugs if you haven't had either done in a while.
20V GTRS
:confused:
You can replace the plugs and coils but the 1.8t does not have wires to be replaced. The 2.0 has wires that can be replaced.
a.k.a. porkchopzz4
NBTurboFreak said:
:confused:
Sorry - didn't notice which forum I was on ;)
I knew this! I really did! :)
